stuttering l28
79-s130
  • Administrators
There is no punctuation/capitalization. There is no MAF (stock). How do you know the TPS is fine? How did you test the injectors? How do you know it's running rich? What do you mean "there are no vacuum"?
1. Isolate the cold-start injector as the source of the richness: Remove the plug from the cold-start injector, and/or remove the thermo-time coolant sensor plug.
2. Ensure the TPS is adjusted properly. You can do this externally with a multimeter by ensuring that when closed one circuit is closed, and that when the TPS opens beyond approximately 30 degrees, the other circuit is closed. Much more good info here: http://atlanticz.ca/zclub/techtips/tps/index.html
3. Ensure the AFM is adjusted properly. I haven't done this, but lots and lots and lots of great info from smart people here: http://atlanticz.ca/zclub/techtips/EFI&fuel.htm specifically: http://atlanticz.ca/zclub/techtips/afm/index.html and http://atlanticz.ca/zclub/techtips/afm/calibration/index.html
Oh, and I think you'll find people a lot more willing to help, if you put a little more effort into your grammar and punctuation.
Good luck,
Dave
