Guest Mr. Big Business Posted January 26, 2003 Share Posted January 26, 2003 big time! I am in the process of replacing all of the gauges in my '71 with autometer phantoms. I went with fuel (using ford version), water temp, and oil pressure for the pods (all electric), and the 5 inch tach and electric speedometer, for the T56. I puzzled for quite a while wondering how to get the new speedo and tach in without resorting to weatherstripping or black caulk. (no offense to those who took that route) I was comparing to the old tach, and I noticed that the casing was almost identical, with exception of the autometer bezel on the front. After much deliberation, I used a dremel to cut off the front of the brand-new never-been-tested tachometer. (yes, I am insane) I went through about 6 dremel cut-off wheels for the tach alone. The depth of the can was the same of the old one, and lo and behold, it fits in the stock bezel/tube! Since the old one was held in with some screws, I used epoxy to hold in the new one, after cleaning all of the dust out of everything. I had thought that the new tach's mounting posts were in the same position as the stock one, but sadly, they are off by about 1 hours worth of clock rotation, so the gauge looked crooked in the dash. I just epoxied (I'm loving this stuff) the bezel to the dash, for both the tach and the speedo. I think I'll still get some black caulk and goop it on the back side of the dash, just to make sure both of those big gauges are secure, since the stock bezel is the only thing holding them on. I put some LED's (radio shack specials) into the tach bezel right in front of the "glass" for the turn signal, brake, and highbeam indicators. They are just being test-fit in that picture. So far I'm pretty happy with how 'stock' they look. There are more pictues here. Henry Quote Link to comment Share on other sites More sharing options...
inZane 240 Posted January 26, 2003 Share Posted January 26, 2003 Wow man that is one of the most creative and impressive things I have seen in a while. Great job! Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted January 26, 2003 Share Posted January 26, 2003 Impressive. thats a good idea...Gauge looks good from the pics. I like the lights in the tach tunnel too. Are you going to put a shift light in the tunnel tube also? Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted January 26, 2003 Share Posted January 26, 2003 Looking good so far. Quote Link to comment Share on other sites More sharing options...
383 240z Posted January 26, 2003 Share Posted January 26, 2003 Looks good thanks for the tip. I'm far from that part of my car but I filed it away for future use. Keith Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted January 26, 2003 Share Posted January 26, 2003 Awsome idea!! Good luck! Mike Quote Link to comment Share on other sites More sharing options...
