wtb 44-50 triple carbs
soullessjdog
Try Wolf Creek Racing for Mikuni stuff. I might advise, 50mm is a bit overkill. A 45mm Dellorto with 38mm venturis, which is pretty much the same as a Weber or Mikuni DCOE, will flow around 258 CFM or so. A Datsun head will only flow 220 maybe 230 CFM from what I've read. Unless you decide you want to start running a more than .6" lift cam and you raise the roof of the intake, I don't think its getting much better...
Here is a link to Wolf Creek:
http://www.wolfcreekracing.com/classified.htm
