badassbowtie Posted January 8, 2010 Share Posted January 8, 2010 I am in the middle of assembling a small chevy and having an issue with the oil pan/ gasket fit. I am using the felpro one piece rubber 34510T gasket that has dipstick provisons on both sides and a thick front seal. The timing cover is a Mr gasket chrome that came with a thick and thin front seal. The oil pan is a Mr gasket for 80-85 motors with the dipstick on the right (passenger) side. Now the problem is the gap from the oil pan to the gasket/block. Its like 1/8 inch on each side (front of the motor). Included are a couple pics. This distance seems excessive to me, I dont want to try and squish the gasket that far. Do any of you have experience with felpro gaskets and how muych "crush" they might have? I cannot find another 1 piece rubber gasket with the dipstick on the passenger side. So what are your ideas of solving this? Thanks for reading this book! Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted January 8, 2010 Share Posted January 8, 2010 (edited) OS34509T: Thin seal OS34510T: Thick seal BOTH LEFT HAND DIPSTICK looks like you need the #OS34509T: Thin seal, but that only comes in left hand so you might be forced to use Right-hand dipstick 375-1818 http://www.jegs.com/p/Fel-Pro/Fel-Pro-Oil-Pan-Gaskets/746664/10002/-1 Edited January 8, 2010 by grumpyvette Quote Link to comment Share on other sites More sharing options...
badassbowtie Posted January 8, 2010 Author Share Posted January 8, 2010 damn I was afraid of that, hate using the non 1 piece gaskets. Thanks for the reply! Quote Link to comment Share on other sites More sharing options...
badassbowtie Posted January 14, 2010 Author Share Posted January 14, 2010 I hae gotten frustrated trying to find a correct gasket and not being able to use this one. After talking with the local machine shop, I set the Felpro on the oil pan and it fits like it should, no gaps. Same when placing it on the block. So I bolted the pan on with the two front bolts and guess what? It snugged up perfectly and IS the correct gasket for this oil pan/block/timing cover combo. Quote Link to comment Share on other sites More sharing options...
