Opinions on this drag launch method
jc052685
So, I have been thinking about this hard for several months and I finaly decided I could use some other peoples opinions on this.
So just to start with here is the setup
'74 early 260z
L28e(t)
Factory 4-spd
3.7 r200
Factory axles
4 puck unsprung ACT clutch (rated 520ft/lbs)
Race weight (2460lbs)
Ok, so the car dynod 305whp / 329ft/lb. I also have a 75wet shot on the car that I have sprayed once. My problem is 1st gear is sooooooo short. I will be running 24.5x8x15 MT ET Drags. Probably going to run them at 12psi. I am thinking if I leave on the spray I can do so in second gear. I think this might also be safer on the axles. I could just be crazy, but hey.
6300rpm shift gives me....
1st - 35mph
2nd - 56mph
3rd - 89mph
4th - 126mph
Compared to a factory Ls1 Camaro
1st - 53mph
2nd - 79mph
3rd - 108mph
4th - 141mph
So looking at these numbers I would thonk a car that weighs 1000lbs less and is putting down nearly 100 more whp it should not be a problem useing second gear to launch. Yes I am very good a clutch control on the launch so I dont thing bogging it down to too low of an rpm will be an issue.
Thanks,
Jeff
As I was telling you over the phone, this could have a similar effect to swapping in a 2.3 diff in place of your 3.7... at least for the first two gears.
for the 3.7:
1st - 35mph
2nd - 56mph
3rd - 89mph
4th - 126mph
with a 2.3
1st - 56mph
2nd - 90mph
3rd - 142mph
4th - 202mph
If you are almost at redline at your trapspeed then I would keep everything as it is and try the 2nd gear start. Otherwise you should adjust your diff ratio until you are at redline in 3rd gear, and use 1-2-3. The question is if that will actually make your car faster. (it follows your theory though.)
Hopefully someone with lots of drag experience can chime in and say if this is a good approach to a lower e.t.
Ok I ran your numbers on the Richmond Gear drag race calculator. You should have a trap speed of 116mph / 125mph with a recomended gear of 3.93 off the nos. and 3.66 with. That makes your 3.7 rear a good choice for both. First gear is more than likely the strongest gear in your trans I wouldn't recomend a 2nd gear launch with nos. and if you drop to much rpm that may also cost you your engine. If it were me I would launch in first and hit the nos in 2nd. This should help you have traction and keep your clutch from geting overpowerd and not letting you get into the next gear, its happend to me. Hope this helped.
