Fusible link to fusebox conversion
I can't seem to find a place that has one. It was a conversion to turn your FL's into a solid black fusebox. But I can't find a place online that has the pic and an order.Do you guys know where I can find a place? Thanks
I think I have seen this question posted several times, but don't know if I have ever seen an answer. Does anyone know the Amp ratings of the fuseable links? Specifically I have a '77 280. Three of the links are the same size, and the fourth is much larger. Before I go and install one of these, I would really like to know what size fuses to use.
Thanks - Greg
  • 1 month later...
  • 1 month later...
I think I have seen this question posted several times' date=' but don't know if I have ever seen an answer. Does anyone know the Amp ratings of the fuseable links? Specifically I have a '77 280. Three of the links are the same size, and the fourth is much larger. Before I go and install one of these, I would really like to know what size fuses to use.
Thanks - Greg[/quote']
Here you go, I just found this. http://home.attbi.com/~zbyter/280ZFusableUpG.html
