S30TRBO Posted January 25, 2010 Share Posted January 25, 2010 So I emailed Blitz direct to see if they have some sort of wiring diagram for the S30 or can draw me something to ease this process since I know they don't make a harness specifically for it and this is what I get: HI SORRY WE DONL;T HAVE ANY DOAGRAM FOR ANY CAR .. YOU HAVE LOOK AT TH SERVICE MANUEL THANKS WTF Has someone wired this in before or any turbo timer for that matter into an S30 that can help a brother out?? I wonder if I can get a better reply if I email Blitz Japan... Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted February 15, 2010 Author Share Posted February 15, 2010 Has anyone installed a turbo timer in a 240Z? Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted February 15, 2010 Share Posted February 15, 2010 Very simple. Wire it to the IGN hot behind your column switch(looping/bypassing the IGN switch), A ground , and usually there's also a wire for the hand brake switch. or a P/N switch. Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted February 25, 2010 Author Share Posted February 25, 2010 Very simple. Wire it to the IGN hot behind your column switch(looping/bypassing the IGN switch), A ground , and usually there's also a wire for the hand brake switch. or a P/N switch. Thanks for the reply. Understood the connect to the IGN hot off of the key from the column. What do you mean by "looping/bypassing the IGN switch"? Quote Link to comment Share on other sites More sharing options...
