Rear main seal installation
Ineptitude01
Okay, guys, I'm gonna swallow my pride and ask, since I've been searching and reading, and I've busted four of these. I have to be doing something wrong.
Is there some kind of magic juju that I need to observe to get the rear main oil seal installed on an L28ET?
The engine is an '82, and the car was auto, stock. I'm pretty sure I removed the spacer plate (1/4" thick disc that went on the end of the crank?).
I've been lubricating/oiling the seals, and I can always get them to the same point: The interior rubber lip is over the end of the crank, and the hard part of the seal is very nearly flush with the metal, and then it just can't be forced on any more, and I'm scared to even tap it with a rubber mallet.
Do I need to just man up and use a seal driver?
PVC pipe cap + old seal + hammer?
Same happened to me and I just used an X-acto knife to cut the little nub off however I wouldn't do that because my rear drips a drop or two of oil each day. Don't know if it was because of that or what. I was just use to the British motor because they give you a little extra on each one which you trim flush.
This is a bit ghetto, but it worked for me: cut a hole in a piece of 3/4" or thicker board that is just larger than the end of the crank. Use a mallet to pound that against the seal. Helps distribute the load more evenly without distorting the seal. I doubt you could tap the seal all the way flush with a hammer in direct contact with it.
Of course, a real seal driver would probably be best...
That sounds a lot better. I was being an idiot when I first did mine and tried to just use a small plastic mallet but of course it would bend it to the left and right and then the top would be all fargled and mushroomed out. :fmad:
Yeah, that was me. I kept bonking it with a rubber mallet, and it would eventually just rip. I guess the thing that was getting to me was the 'How to Rebuild Your Datsun/Nissan Z Engine' book just showing a guy slipping it over the crank. That's what killed the first one.
I'll try that trick with the wood block this weekend, I suppose. You cut the hole in the middle to clear the very center of the crank, I'm assuming?
Is the end of your crankshaft the same diameter from the flywheel side all the way to the journal? I thought when I pulled my flex plate off there were 2 spacers on my auto tranny setup, but I could be wrong. I had to knock the spacer off with a hammer. But my rear main seal went on nice and easy with some assembly lube.
Where did you get the seal from?
Exactly. Trim the piece so it's reasonably sized of course. Plus, make sure you keep the wood flush with the seal, otherwise you'll damage the seal same as if you hit it directly with the mallet.
Ohhhhhhhhhhh! I was talking about the wrong one! :mrgreen: I was talking about the 2 little rubber sticks that seal between the rear main cap and the block. For me, there was like 1/4" of it sticking up which prevents the oil pan seal from sitting flush, so I cut the excess off. The one that seals around the crank, use some anti seize and a little block of wood. I just happened to use the same block that I used to knock out rusty pistons from the bottom.
I've tried just about every kind except Nissan. My current candidate is a Beck Arnley.
The end of the crank isn't the same size all the way to the journal, no. Is that another spacer? It looks like it's made of the same material as the crank, and I didn't notice any kind of seam... It would have to have been pressed on flush, and I figured it wasn't anything like that.
Does anyone have a picture of how it should look? I'm gonna feel real dumb if something like this is what's screwing me over.
Man, I didn't even consider that this thing could be a spacer. There was some little disk, couldn't have been more than a 1/4" thick, and I thought that was it.
I feel so much better now. I kept reading posts where everyone was going on and on about how easy it was. Come to think of it, the spacer makes sense, since the flexplate is so thin.
