Guest TurboHatch Posted January 30, 2010 Share Posted January 30, 2010 I searched and found two threads about backlash, 1 says that .003-.007 is the range and another says .004 to .008 is the range, well that aside i planned on measuring the open diffs backlash and just matching it once i swap the LSD over so this brings me to my question, I currently have a r200 with a 3.70 geared LSD and I just bought a 3.54 open r200 my plan is to just swap over the LSD to the 3.54 in doing so should i just be able to reuse the shims from the open carrier or will the diffs be machined different that i might have to use the shims from the LSD carrier or a mix and match of both? basically I am looking for people that have done this and see what they ran into before I get started. Quote Link to comment Share on other sites More sharing options...
johnc Posted January 30, 2010 Share Posted January 30, 2010 should i just be able to reuse the shims from the open carrier or will the diffs be machined different that i might have to use the shims from the LSD carrier or a mix and match of both? Most likely a mix and match. Quote Link to comment Share on other sites More sharing options...
lubu Posted January 30, 2010 Share Posted January 30, 2010 Backlash is .0051 to .0071 Quote Link to comment Share on other sites More sharing options...
Guest TurboHatch Posted January 30, 2010 Share Posted January 30, 2010 Backlash is .0051 to .0071 now thats the third different answer to that question i have found on the forums lol can any one chime in on this as well? Quote Link to comment Share on other sites More sharing options...
johnc Posted January 30, 2010 Share Posted January 30, 2010 What's the big deal? Every single range you've found eventually works down to .005 to .007. Shoot for something in that range. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted January 31, 2010 Share Posted January 31, 2010 The shims should be the same if you're using a Nissan LSD. If it's something else then they might be different. Mine changed from .005 to .0055 when I swapped the open for the Nissan LSD. Just measure before and after, and if it's different after, shim it to the before measurement to keep the wear pattern on the gears right and you're good to go. Quote Link to comment Share on other sites More sharing options...
Guest TurboHatch Posted January 31, 2010 Share Posted January 31, 2010 did you find that the .0005 was enough to make noise or did you go threw the effort to bring it back exactly to .005 Quote Link to comment Share on other sites More sharing options...
lubu Posted January 31, 2010 Share Posted January 31, 2010 John is right, as long as you're in that range you should be fine. Those numbers came from the FSM btw. Quote Link to comment Share on other sites More sharing options...
