patrickhove Posted January 30, 2010 Share Posted January 30, 2010 I have an s30 with ground control coilovers and tokiko illuminas. My rear springs are adjusted to an uneven ammount the left side spring sits higher than the right side. Did I do something wrong or is this how these cars are thanks Quote Link to comment Share on other sites More sharing options...
JMortensen Posted January 31, 2010 Share Posted January 31, 2010 Are the perches an equal height from the bottom of the strut? Did you put the same size spacer under the strut on each side? Are you using the same rubber isolator on top (240 and 280 are different heights, I think front and rear are also different on 280)? You shouldn't have to have one side noticeably higher than the other if all you're trying to do is get the ride height even. Quote Link to comment Share on other sites More sharing options...
