Jonathan Russell Posted February 6, 2010 Share Posted February 6, 2010 As I plan for my future LS swap, I have read thread after thread learning about the approaches many of you have taken in accomplishing your LS swaps. It seems fairly common that the engine / trans assembly goes in and out several times between fitment, a little tunnel pounding, some cuts here and there, etc, before the unibody is sent off for paint and then final engine / trans install. It seems that it would be useful to have an exactly sized light plastic model of the engine / trans assembly I am going to use. That way, maybe I could reduce the number of times the actual engine goes in and out. Does anything like this exist? Would it really be useful or am I over reading the number of times the assembly really gets swapped? Thanks. Quote Link to comment Share on other sites More sharing options...
m1noel Posted February 6, 2010 Share Posted February 6, 2010 vanpeltsales.com LS1 block with heads $360 around 20lbs. I believe they have trannies too. Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted February 7, 2010 Share Posted February 7, 2010 When doing my swap, I only put the engine in once and never had to take it back out. That is.... until I blew it up. Quote Link to comment Share on other sites More sharing options...
blueshark123 Posted February 9, 2010 Share Posted February 9, 2010 someone on silviav8.com rents his out Quote Link to comment Share on other sites More sharing options...
