bobbyc Posted February 8, 2010 Share Posted February 8, 2010 has anyone used the 115v harbor freight spot welder? i recently picked up a project 97 4runner with front end damage...i removed the radiator support and have another one on the way...i would like for this to look factory as much as possible so i want to avoid plug welds....just lookin for some insight... Quote Link to comment Share on other sites More sharing options...
Khaserwolf Posted May 18, 2010 Share Posted May 18, 2010 I was acctually thinking of picking up the 230 volt one. im intrested to know if it would do the trick also? Quote Link to comment Share on other sites More sharing options...
Snailed Posted May 18, 2010 Share Posted May 18, 2010 has anyone used the 115v harbor freight spot welder? i recently picked up a project 97 4runner with front end damage...i removed the radiator support and have another one on the way...i would like for this to look factory as much as possible so i want to avoid plug welds....just lookin for some insight... The smaller ones are nice to have if you are doing something thin, like 19g thinner. Another draw back of the smaller/cheaper spot welders is that the jaws can't clamp as tight as you might want so you would have to dolly the areas for each weld so they mate nicely. If you get one make sure to do a few destructive tests to make sure you are getting a good weld. Quote Link to comment Share on other sites More sharing options...
bobbyc Posted May 19, 2010 Author Share Posted May 19, 2010 i bought one...it wouldn't reach the areas i was lookin to spot weld...just ended up doin a plug weld...much easier...i took it back...thanks guys! Quote Link to comment Share on other sites More sharing options...
