phantom grip r180
gjc5500
will a phantom grip for a r160 or one for a r200 work in a r180? looking for a cheap, fast lsd solution.
thx in advance
-=gabe=-
I would say no. I've made a few, and they must be made for each individual diff center. The clearances are quite important if it is to work properly.
Edited by valvebounce
was the rear end of choice in the 70s for road racing :)
granted the only other option was open so...
cheap and fast = compromises and unreliable results. I went the Phantom grip and while it worked for a while, it wasn't long before my diff. fluid looked like glitter-glue. Shortly there after a continuous hissing from the NLA pinion bearing.
I'd agree cheap and fast, and sure two wheel drive, is welded spiders. After that check out the OBX thread. Not sure if they make for r180, but best add-on to date for mine.
Edited by John Scott
