Clutch Replacement any suggestions?
DuoWing
Well I took my 300ZX out for the first time in a while last week as the weather was finally getting warm. The clutch is finally about toast it was slipping really bad if I began to give it even moderate throttle in a higher gear. Full throttle runs or even hard accelerating is something that is not possible. Even getting on the freeway wasn't too fun.
Well anyway I went ahead and ordered an ACT Street Performance Clutch Kit for my 87' Z31 Turbo. I got a gallon bottle of Redline MT-90 to refill the tranny with while I'm at it. I was curious if you guys had any other suggestions on things I should do or get?
If your doing an ACT then get a nice stainless braided clutch hose and a new slave cylinder. It may be worth your while to do the rear main while your at it. Also your rear tranny seal is a must. Make sure your master is good too cuz I just got my clutch and tranny replaced and did everything but the master and its now bad.
