pat1 Posted April 15, 2010 Share Posted April 15, 2010 (edited) wiring guide for installing a rb20det in to a datsun ZI'm hope this will help some people wire up a rb20 into there datsun Z. The wiring is very easy and anybody can do it. If you have installed a radio,cd player in to any car YOU can do this.First thing install the engine and run your wiring harness in to the cabin. Find a spot on the drivers side kick panel to mount the ecu. I have a 280z so I put the ecu in the stock location.here is the pin out diagram for a rb20det. FireShot Screen Capture #375 - 'RB20_ECU_Pinouts_jpg (800×459)' - wiki_r31skylineclub_com_images_9_9b_RB20_ECU_Pinouts.pdfhttp://wiki.r31skylineclub.com/images/9/9b/RB20_ECU_Pinouts.jpgstudy this and print it out.Here is the wiring guide for the rb20**Edit** Link Dead > http://www.rbforums.org/pics/rb20.jpgprint this also you will need it.Ok now it's time to get to work on the wiring.On your rb20 loom you will find a connector thats on the same loom as the connector for the airflow meter. The connectors you are looking for is a two 8 pin connectors. One is blace and the other is gray.On this connector you will find 3 wires that need power. 2 for the wires need constant power from the battery. They are a white wire with a purple tracer(W/P) and a white wire with a black tracer (W/BL) and the next wire will need a switched power. Meaning that it needs power with the ignition on that wire is Black with a red tracer(B/R).You can find the constant power and the switched power off the wiring going to your ignition switch. This is easy to find using a test light or a DVOM meter.Next you will need to wire up the fuel pump.First thing you will need is a 30 amp relayconnect one side of the relayusing your ecu pin out print out I provided aboveconnect one side of the relay connector 86 to switched power(Meaning power with the key in the on position).connect the other side relay connector 85 to wire from ecu terminal 18 which is the Black wire with purple tracer (B/P)Now connect the relay connector 87 to the wire going to the fuel pumpand connect the relay connector 30 to a body groundnow with the key turned to the on position you should hear the fuel pump runningNow it's time to hook up your alternator,starter and reverse switch on the trans.I used this page to convert my alternator to a internal voltage regulator. FireShot Screen Capture #376 - 'Nissan_Datsun Z Car Voltage Regulator Conversion' - www_zcarcreations_com_howto_voltreg_htm.pdfhttp://www.zcarcreations.com/howto/voltreg.htmthis is a very good write up on converting your alternator.Hook up your stock reverse light wiring to the rb reverse switch.I used the stock z speedo sender, I just swapped out the rb for the stock z speedo sender. I had to trim down the holder down abit with a grinder.hook up the power cable to the starter and ground out your negitive battery cable to the block as it was on the stock Z engine.Now for the gauges I used autometer gauges, Which is alot more relieable than the 30 plus year old z gauges.I used this diagram to hook up my autometer tach to the rbNow there are a few more wires that need to be hooked up and then you are done.pin number 44 on the ecu is the neutral switchthere is two ways to hook this up. One way is just to ground it out or run a wire to the neutral switch on the trans. This wire tells the pcm thats is in neutral.Now you need to hook up the start signal pin number 43 to the signal wire going to the starter solenoid this wire powers up the iac valve and the ecu tell the iac vale to idle up. This wire NEED to be hooked up or it will start like crap.You can hook this wire to the back of the ignition switch Black wire with yellow tracer (B/Y)Now with the ECU disconnected check all the powers and grounds at the ecu with a DVOM meter. And then you are done. This is easy. Edited September 30, 2015 by RB26powered74zcar 1 Quote Link to comment Share on other sites More sharing options...
ghostu2 Posted April 15, 2010 Share Posted April 15, 2010 Thank You, I really appreciate the instructions Just need to get my Mckinney swap mounts and Im in the home stretch. Quote Link to comment Share on other sites More sharing options...
WanganDevilZ Posted April 20, 2010 Share Posted April 20, 2010 On your rb20 loom you will find a connector thats on the same loom as the connector for the airflow meter. The connectors you are looking for is a two 8 pin connectors. One is blace and the other is gray. On this connector you will find 3 wires that need power. 2 for the wires need constant power from the battery. They are a white wire with a purple tracer(W/P) and a white wire with a black tracer (W/BL) and the next wire will need a switched power. Meaning that it needs power with the ignition on that wire is Black with a red tracer(B/R). Next you will need to wire up the fuel pump. First thing you will need is a 30 amp relay connect one side of the relay using your ecu pin out print out I provided above connect one side of the relay connector 86 to switched power(Meaning power with the key in the on position). connect the other side relay connector 85 to wire from ecu terminal 18 which is the Black wire with purple tracer (B/P) Now connect the relay connector 87 to the wire going to the fuel pump and connect the relay connector 30 to a body ground now with the key turned to the on position you should hear the fuel pump running +100 to appreciation, but I'm a little bit confused, could you provide pictures of the said steps? I've been sitting in my driveway scratching my head all afternoon, it took me a while to find the FP relay, and now I dont know what to do with it xD! Quote Link to comment Share on other sites More sharing options...
palauoriginal Posted April 20, 2010 Share Posted April 20, 2010 you the man. ty pat1 next person to do this take pics! Quote Link to comment Share on other sites More sharing options...
pat1 Posted April 21, 2010 Author Share Posted April 21, 2010 +100 to appreciation, but I'm a little bit confused, could you provide pictures of the said steps? I've been sitting in my driveway scratching my head all afternoon, it took me a while to find the FP relay, and now I dont know what to do with it xD! I wish I took pictures but I installed my rb last aug/sept and I didn't think about taking pictures. I did this write up from memory and sitting down one night and looking at the wiring diagram. I used a aftermarket 30 relay got at a parts store and ran new wiring to the fuel pump. Quote Link to comment Share on other sites More sharing options...
WanganDevilZ Posted April 21, 2010 Share Posted April 21, 2010 (edited) I wish I took pictures but I installed my rb last aug/sept and I didn't think about taking pictures. I did this write up from memory and sitting down one night and looking at the wiring diagram. I used a aftermarket 30 relay got at a parts store and ran new wiring to the fuel pump. Is it absolutely necessary to use a 30amp? What would happen if i used the current relay on my Z? Edit: Also, did you use your stock engine bay fuse box or the RB20 fuse box? Edited April 21, 2010 by WanganDevilZ Quote Link to comment Share on other sites More sharing options...
pat1 Posted April 21, 2010 Author Share Posted April 21, 2010 You can use the stock fuse box and the stock fuel pump relay Quote Link to comment Share on other sites More sharing options...
WanganDevilZ Posted April 21, 2010 Share Posted April 21, 2010 (edited) You can use the stock fuse box and the stock fuel pump relay After a bunch of knuckle bruising I think I may be getting it done correctly. Edit: Still failing. Then again I dont know if my ground is grounded. I have the BLU/RED wire on my fuel pump relay (Fuel pump relay on ECU) connected to ECU terminal 18 (Labeled: Fuel pump relay) (BLK/PNK) I also have WHT/BLK on my fuel pump relay connected to the WHT/BLK wire on my ignition, which should be ACC? What is wierd, is that my clock does not turn off. Even with the key removed from the ignition. I also have wire 43 from the RB20 ECU which is ignition switch START signal, and i'm looking at wire 45, which is IGN Ignition switch. Did i kind of do it right? Think you could unscrew your kick panel and take a lookski? Edited April 22, 2010 by WanganDevilZ Quote Link to comment Share on other sites More sharing options...
pat1 Posted April 22, 2010 Author Share Posted April 22, 2010 lets start with pin number 43 which is the start signal. This wire needs a 12v signal only when starting. Behind your ign switch you will have the wire that goes to the start solenoid which gives a 12v power to starter when starting. My wire was black/yellow tracer (B/Y). Run a jumper from pin 43 to the B/Y wire. Your wire might be a different color. Do this grab a test light and check each wire on the ign switch. With the key turned to start find the wire that is 12v+ the run the jumper from the pin 43 to that wire and that part is done. the pcm supplys the relay with a negitive signal from ecu pin 18, connect one side of the relays coil wire to 12v +. Connect pin number 18 to the other side of the coil on the relay. On the contact side of the relay connect the wire going to the fuel pump and the other contact connector on the relay connect it to ground. that should be it Quote Link to comment Share on other sites More sharing options...
WanganDevilZ Posted April 22, 2010 Share Posted April 22, 2010 lets start with pin number 43 which is the start signal. This wire needs a 12v signal only when starting. Behind your ign switch you will have the wire that goes to the start solenoid which gives a 12v power to starter when starting. My wire was black/yellow tracer (B/Y). Run a jumper from pin 43 to the B/Y wire. Your wire might be a different color. Do this grab a test light and check each wire on the ign switch. With the key turned to start find the wire that is 12v+ the run the jumper from the pin 43 to that wire and that part is done. the pcm supplys the relay with a negitive signal from ecu pin 18, connect one side of the relays coil wire to 12v +. Connect pin number 18 to the other side of the coil on the relay. On the contact side of the relay connect the wire going to the fuel pump and the other contact connector on the relay connect it to ground. that should be it where are your grounds at? I'm having trouble finding them, and im sure that's my problem. Quote Link to comment Share on other sites More sharing options...
WanganDevilZ Posted September 6, 2010 Share Posted September 6, 2010 I know this is a late update, but its really my only day to be working on this with such a nice day outside, and it bein labor day and all, I thought it would be nice to give my Z a few hours labor.The only "Connectors" i have, two are green, one is white, and one is gray/whitePics y0!W/P, W/B, W, OrangeFirst connector is on left. Right connector is B/W, W/B, W/B, and Orange, which is connected to the other connectorG/W, W/B, Orange, CyanCyan, Cyan Red, Cyan Black, Orange, and BlackNo 8 pin connectors like you described. D=Edit: I found a gray connector that I had fail spliced a few months ago, it is a round gray connector with an orange inside, its colors are B/W, W, Black, and another black. I must have known something a few months ago because it was connected to my AFM, but it didnt look right...Any help would be extraordinary! Quote Link to comment Share on other sites More sharing options...
WanganDevilZ Posted September 7, 2010 Share Posted September 7, 2010 (edited) You will need to wire up the fuel pump. First thing you will need is a 30 amp relay connect one side of the relay using your ecu pin out print out I provided above connect one side of the relay connector 86 to switched power(Meaning power with the key in the on position). connect the other side relay connector 85 to wire from ecu terminal 18 which is the Black wire with purple tracer (B/P) Now connect the relay connector 87 to the wire going to the fuel pump and connect the relay connector 30 to a body ground The wires for the fuel pump are Bl/G, W/B, B, and another color. Now, there is a relay hooked up near the interior fuse box, and there is also one with identical wires near the fusible links box, except it has a yellow wire in addition. Which one is which? Edited September 7, 2010 by WanganDevilZ Quote Link to comment Share on other sites More sharing options...
zzzzed Posted October 23, 2010 Share Posted October 23, 2010 can this please be pinned Quote Link to comment Share on other sites More sharing options...
70 Cam Guy Posted November 10, 2010 Share Posted November 10, 2010 Thanks for writing this Pat1! I am piecing things together for the rb20det swap and this will prove exceedingly helpful. When my project really starts I'll be documenting it. Still waiting for the ARP head studs but have the Nissan gaskets and timing belt kit already. The motor will get a basic reseal because it's on the stand. The Thai Threddy intake arrived today so I'll be using that with a nice (ebay) front mount and stock turbo. A nice dump pipe should help spooling and response. The basic plan is bolt-ons that won't require special tuning. I'm going to see where the boost settles with the basic setup and see if I want to run a manual boost controller like a Hallman. Definitely getting excited for the swap Quote Link to comment Share on other sites More sharing options...
BloomZ Posted June 8, 2011 Share Posted June 8, 2011 I just got my rb20det running in my 280z. The fuel pump steps can be simplified by just splicing the fuel pump signal wire to the ign wire. This way when you turn your car on the fuel pump runs regardless. this also leaves room for a toggle switch if you so please. if anyone has any questions on the wiring just pm me and ill try and help. Quote Link to comment Share on other sites More sharing options...
pecx Posted December 12, 2012 Share Posted December 12, 2012 Would this work on red top RB20det off 200zr? Quote Link to comment Share on other sites More sharing options...
pat1 Posted December 13, 2012 Author Share Posted December 13, 2012 Some of it will work. The red top is a little bit different. Quote Link to comment Share on other sites More sharing options...
3ryce Posted February 10, 2013 Share Posted February 10, 2013 yes this should be pinned. Quote Link to comment Share on other sites More sharing options...
Niall280ZX Posted August 12, 2015 Share Posted August 12, 2015 Hey Pat, the link for the wiring guide is dead. Do you know of another one or is that in the fsm? Quote Link to comment Share on other sites More sharing options...
Wizzurp Posted September 30, 2015 Share Posted September 30, 2015 Thank you for taking the time for making this, I had my car wired in in less than 30 minutes! Had to figure out my eccs relay wiring but that was it. Quote Link to comment Share on other sites More sharing options...
