radiator hose adaptor
bjhines
I needed an adaptor and drain for my lower radiator hose. One side is 1.25" and the other is 1.75". I left a center flange to drill and tap for 1/4NPT for a lower drain. I could also use this for a temp sender if need be... or I can drill 2 holes and tap the other 1/8NPT for the sender and a drain together.
I started with 2"dia. 6061-T6 round stock. I cut off a suitable piece with the carbide chop saw. It took me an hour at least to get this thing worked down to size, inside and out on both ends.
