xxxpatsabxxx Posted May 7, 2010 Share Posted May 7, 2010 Hey everyone ive recently rebuilt my weber dgv setup and the car doesnt idle well at all, ive tried adjusting the idle air screws and the air mixture screws but nothing seems to work. the car starts at an extremely high RPM (my tach doesnt work) but the car dies or drops to extremely LOW RPM when put into reverse/drive. any help will be great, ive been reading up but havent found anything. hours of work but no progress. - PatSab Quote Link to comment Share on other sites More sharing options...
sticky280zx Posted May 8, 2010 Share Posted May 8, 2010 vacuum leak? Quote Link to comment Share on other sites More sharing options...
xxxpatsabxxx Posted May 9, 2010 Author Share Posted May 9, 2010 (edited) vacuum leak? well i've got a vacuum tester, tried it out, but it isnt far from the "normal engine" vacuum. ill try to take some pics of the tester in action tomorrow. Edited May 9, 2010 by xxxpatsabxxx Quote Link to comment Share on other sites More sharing options...
xxxpatsabxxx Posted May 23, 2010 Author Share Posted May 23, 2010 so my fuel pressure regulator came in and i got it installed. the carbs have a more consistent reaction but the idle is still ridiculously loud. another thing i noticed today was the chokes MUST be closed for the car to continue to run, as soon as the manual choke lever moves the slightest bit forward the engine dies. soooo.... i guess i have a vacuum leak somewhere or i need to start back at square 1 and do a complete teardown and reinstallatiion of everything to make sure all gaskets are sealing. Quote Link to comment Share on other sites More sharing options...
xplosiveg06 Posted August 18, 2010 Share Posted August 18, 2010 i have that same problem with my dgvs. were you able to find a solution to the problem? Quote Link to comment Share on other sites More sharing options...
