borini63 Posted May 10, 2010 Share Posted May 10, 2010 Hi guys....I am wondering if the antenna cable(the long antenna cable from the front to rear)from 280ZX will fit 280Z ....are they the same length or longer or shorter? I like it to be longer not shorter! Did anybody went through this before. Please help and thank you in advance. Jamal Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted May 10, 2010 Share Posted May 10, 2010 i bought one from radio shack. I think it was 20 feet. worked fine the connectors on the ends are standard. Quote Link to comment Share on other sites More sharing options...
borini63 Posted May 11, 2010 Author Share Posted May 11, 2010 Thanks for the input. Jamal Quote Link to comment Share on other sites More sharing options...
zxtoy Posted May 11, 2010 Share Posted May 11, 2010 It should work fine. The one on my 80zx isn't tight anywhere. It has an easy couple feet of slack and I'll bet the distance from radio to mast is longer on the zx than the z. Quote Link to comment Share on other sites More sharing options...
borini63 Posted May 12, 2010 Author Share Posted May 12, 2010 It should work fine. The one on my 80zx isn't tight anywhere. It has an easy couple feet of slack and I'll bet the distance from radio to mast is longer on the zx than the z. Thank you....that's what I thought....the cable in the ZX is longer than the S30.... Thank you. Quote Link to comment Share on other sites More sharing options...
zxtoy Posted May 15, 2010 Share Posted May 15, 2010 Glad to help. You are welcome. Quote Link to comment Share on other sites More sharing options...
