Guest Night_rider_383 Posted August 17, 2001 Share Posted August 17, 2001 My desk top dyno messed up and i wanted to see what yall think the horsepower and torque on this engine would be. Heres the specs. 355 c.i.d 4.030'' X 3.48'' 9.35:1 compression .030'' over hypereutectic pistons double roller timing chain crane power max 272/284, 216/228@.050'', .454''/.512'' lift hyd cam. 896 castings 1962 327 iron power pak heads enlarged valves to 1.94/1.50's and i think they are 60 cc's but aint 100% sure manley 1 pc. stainless performance 1.94/1.50 valves port work on the bowls, exhaut ports, and intake runners 4.166'' X.041'' head gaskets k-motion 115 lbs valve springs crane 1.5 roller rockers summit hei dist. with a 48,000 volt coil with the 60 cc heads total compression should be about 10.52:1 Any good guess would be a big help. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 17, 2001 Share Posted August 17, 2001 375? Probably low, but better to err on the conservative side and be pleasantly surprised. Davy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 17, 2001 Share Posted August 17, 2001 330 at the flywheel... heh Quote Link to comment Share on other sites More sharing options...
pparaska Posted August 17, 2001 Share Posted August 17, 2001 If you can get me flow numbers for those heads, I'd be glad to run it through DD2000 tonight. I'd say 350-400 flywheel HP, not sure. I think the 375 guess is pretty good. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 17, 2001 Share Posted August 17, 2001 I'll say 376.. I've seen the price is right before... Regards, Lone Ps seriously though, between 375-400 is probably a real good guess. Not a bad result at all for a moderate 350. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 17, 2001 Share Posted August 17, 2001 Trying to "one-up" me, eh Lone? Davy Quote Link to comment Share on other sites More sharing options...
Lone Star 1 Posted August 18, 2001 Share Posted August 18, 2001 I'm going to to say 331 just in case. Quote Link to comment Share on other sites More sharing options...
fl327 Posted August 18, 2001 Share Posted August 18, 2001 i say minimum 300hp to the wheels, and whatever that is 300+300*.15, and pretty dang tough.... Quote Link to comment Share on other sites More sharing options...
Guest Night_rider_383 Posted August 18, 2001 Share Posted August 18, 2001 Thank's yall. Yeah i was thinking along the same lines like 350-400 hp, but for a $1841.00 build from chrome air cleaner down to oil pan, plugs and wires, dress up kit,machine work, etc that aint bad at all. Pparaska i wish i could get you the flow numbers but i have no clue where to find printed numbers on these heads and i dont have a flow bench in my shop. I guess i could make a trip to a speed shop that has a bench but thats alot of money and what we are tryin to do is me and dad build him a car that will last for everyday use, hit high 11's low 12's, get 18 mpg or better and all for under $3500.00. I'm doing most of the work for him and he's footin the bill and his buget for this is 3500. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 19, 2001 Share Posted August 19, 2001 Thats a pretty good price on that motor. It cost that much just to dress out a stock 350 pretty much. Sounds like a nice stout street engine from the specs. Should be fun. Regards, Lone Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted August 20, 2001 Share Posted August 20, 2001 quote: Originally posted by Night_rider_383: ...9.35:1 compression .030'' over hypereutectic pistons..,with the 60 cc heads total compression should be about 10.52:1..,Any good guess would be a big help. Night Rider, How did you determine your 9.35:1 Comp.Ratio? If your engine hasnt been machined in anyway then your 60cc cyl.heads (using .030 350SBC pistons) would yield 11.4:1 w/your choice of head gasket providing your piston's had a .060cc dish! If you chose that same set up w/.060cc Dish Pistons and 70cc Cyl.Heads...then comp.ratio would be in the 10.1:1 to 10.2:1 Comp.Ratio. If this is a street engine...be careful of your cyl.head selection. Dont guess when it comes to Comp.Ratio's. Remember you have to consider: 1) Cyl.Displacement cc's 2) Cyl.Head Combustion Chamber cc's 3) Head Gasket Crush (.041 on yours) 4) Piston Dish or Pisto Dome/Flat Top cc's 5) Piston Comp Ring cc's (Top Piston Ring) Then the "X" factor...your camshaft, as it will effect Dynamic Comp.Ratio. Providing you've made the needed checks/balances for Static Comp.Ratio your engine sounds like it will be very stout! I too would guess in the 350 to 400hp range. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Guest Night_rider_383 Posted August 20, 2001 Share Posted August 20, 2001 Kevin... The 9.35:1 with 64 cc heads came from summits catalog and yes i know this is just a baseline number cause alot can change compression. From what i get when you see a compression on pistons in like summit its calculated with .030'' over pistons, 64 cc heads, stock deck height etc. etc. But the pistons is sterling hypereutectic flat tops i would say -3 to 4 cc valve reliefs. Oh i would like to add this aint gonna be a pure drag car, more or less daily use with alittle strip time, This is for my dad and heres the 3 cars he's thinking about datsun 280 z, 86 mazda rx 7, or 85 ford ranger, the rx-7 will have a 3.91 gear, the ranger will be a 3.73, His pick for a trans is a t-5 5 speed man. out of a mid to late 80's camaro/firebird, max rpm it will ever be turned up too will be about 58-6000. Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted August 21, 2001 Share Posted August 21, 2001 Night Rider, BTW; your first post mentioned 60cc cyl.heads while your last posting mentions 64cc cyl.heads. 64cc cyl.heads will leave you w/a 10.3:1 to a 10.4:1 Comp.Ratio. If you're using alluminum cyl.heads you should be okay, but, if you're using iron cyl.heads you might be pushing the pump gas factor a little too much (detonation?). Unless the piston mfg has altered the Piston Compl.Height your static comp.ratio w/you choice of piston indicates 10.35:1; a 350SBC has a piston comp.height of 1.560". Were those 3 to 4cc valve reliefs (eye brow reliefs) only one relief per valve or were there two valve reliefs for each valve...could make a sizeable difference! Is each valve relief 3 or 4 cc's or is the 3 or 4cc's a total? Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Guest Night_rider_383 Posted August 21, 2001 Share Posted August 21, 2001 Kevin... summit list piston compression ratio with 64 cc heads thats where the 9.35:1 and 64 cc heads came from where i'm gonna be using 327 powerpak heads 60 cc. I know this will have my c/r at an almost to much for iron heads and 93 octane fuel, but i think i can play that by. The pistons has one high lift deep valve relief per valve. The -3 to 4 cc is total per piston Quote Link to comment Share on other sites More sharing options...
