Lean issues ? l28ET
Ive been working on this 73 for a few years now. In its newest form its powered by a 83 hydro lifter head l28et. Ever since it was first installed it had a strange cut in the high rpm high boost area like a Total fuel cut, I figured I was to high of an RPM and just stayed away from it. Tack doesn't work so its by ear, anyways onward... I have a MSA down pipe to 2.5 crappy "turbo" reverse flow muffler, 75 intake, 2.5" IC piping and recently a Intercooler... with just piping and BOV (for drivable mock up)works great. Ran a little lean bone cold but as expected with stock ECU. BUT when the IC was put in it acts lean very easily now. I even bought a FPR with gauge and bumped FP From 32PSI right? to 40PSI. Seamed better but Its still not good. This set up ran 9 of 10 before the IC, now Its down to a 5. Isn't anyone else running an IC on the stock ECU?
MSnS is in the future, its just so hard to let go of all that cash as I need one assembled... Any help is appreciated.
Oh can I hook the old 83 tack wire directly to my 73 tack?
you need a resistor for the tach. Have you checked for any leaks in your I/C piping.
