1972 240z Posted June 12, 2010 Share Posted June 12, 2010 (edited) My rb25det is hard to start when its been sitting overnight. If i spray it with carb cleaner it will start right up but by itself its hard. Injectors are clean and it has good fuel pressure and all the vacuum hoses are in the right spot. Also the MAF and temp sensor seem to be working alright. Has anyone ever had this problem? Please help! Thanks, Edited June 12, 2010 by 1972 240z Quote Link to comment Share on other sites More sharing options...
Snailed Posted June 12, 2010 Share Posted June 12, 2010 Does the fuel pump prime for a few secconds with the key on? Try cycling the key a few times to build up fuel pressure before starting. If it starts, than you may have a leak somewhere externally (line, fitting, injector etc.) or back into the tank through the pump. What pump(s) are you running? Quote Link to comment Share on other sites More sharing options...
280zjoel Posted June 12, 2010 Share Posted June 12, 2010 Try adjusting the Air Idle control valve, That might fix it. Quote Link to comment Share on other sites More sharing options...
1972 240z Posted June 12, 2010 Author Share Posted June 12, 2010 Does the fuel pump prime for a few secconds with the key on? Try cycling the key a few times to build up fuel pressure before starting. If it starts, than you may have a leak somewhere externally (line, fitting, injector etc.) or back into the tank through the pump. What pump(s) are you running? Its a pump i had from a Toyota aristo, it does prime for a few seconds and i checked for a leak i had one in the tank and fixed it and still having the same problem. Ive check for other leaks and couldn't find any. Quote Link to comment Share on other sites More sharing options...
1972 240z Posted June 12, 2010 Author Share Posted June 12, 2010 (edited) Try adjusting the Air Idle control valve, That might fix it. i already looked at it and it was stuck after it fixed it it still had the problem but did start a little easier. How do you adjust it? Edited June 12, 2010 by 1972 240z Quote Link to comment Share on other sites More sharing options...
1972 240z Posted June 13, 2010 Author Share Posted June 13, 2010 Would too much fuel pressure do that? Quote Link to comment Share on other sites More sharing options...
1972 240z Posted June 13, 2010 Author Share Posted June 13, 2010 What is everything on the engine that controls how much fuel it gets and how do i check them to make sure they are working properly? Thanks, Quote Link to comment Share on other sites More sharing options...
