how to clean a master cylinder
so i pulled the master cylinder off my 260z today due to the massive amount of gunk visable when the caps were opened. i disconnected the hard line at the caliper the other day and clean fluid came out so i think the build up is isolated to the cylinder. anyway, my question is what would be the best way to clean the gunk out of the master cylinder. i scraped out what i could with a flathead screwdriver and sprayed the rest in carb cleaner. i only ask because if a good cleaning is all this needs id much rather do that than purchase another one. thanks in advance.
You should buy a rebuild kit if the cylinder it self is good. A kit will come with all new seals. Rockauto.com has one.
I did this a few weeks ago. What I did was use a long narrow screw driver with a scotch brite in my parts washer. It came out pretty good, except the very back wall was tough to clean.
I think you could also buy a hone and use that.
Honing an aluminum master cylinder is not a good idea. It will remove the protective coating from the inside of the bore and result in rapid seal wear. If the bore is in bad shape then the master cylinder should be replaced.
Nigel
'73 240ZT
Nigel
'73 240ZT
I didn't know you couldn't hone an aluminum master cylinder. Good thing I didn't do that I guess! :blink:
I used compressed air through all the holes until nothing blew out then forced water through it and compressed air again and kept doing that until it was clean then let it dry for a couple of days. Then I used 0000 steel wool in the cylinder, it did not leave any scratches on the surface, probably did not need to use it but I did. The cylinder did not have any pits or groves in it, if it had I would have gotten a new one. So far so good, 4 months in and no leaking and it holds pressure.
