Guest the_dj Posted April 8, 2002 Share Posted April 8, 2002 Are fender flares and a 5 lug conversion all it takes to fit (some) aftermarket rims 10 to 12 inches wide (rear) and maybe 8 inches wide (front)? From what I see, properly offset wheels will fit behind a set of wide flares. Just looking for confirmation. Thanks, DJSS Quote Link to comment Share on other sites More sharing options...
fl327 Posted April 8, 2002 Share Posted April 8, 2002 you dont have to go five lug at all to run tires like that, it does make it a lot easier though, you might just have to get longer wheel studs and use spacers to get 10 or twelve inch wide wheels. flares definitely. i just wont go five lug cause i aint trying to pull no stub axle until i shear it off, thats real talk, it likes where its at too much for me to disagree. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted April 8, 2002 Share Posted April 8, 2002 It is possible to fit an 8"/245 combo on the front without flares using stock spring set-ups. Anything wider than that will pretty much require some flaring. And even moderately-to-highly prices wheels can be had in large widths even in the 4 lug pattern (mine are 11"/315 combos) Quote Link to comment Share on other sites More sharing options...
