280z fuel issues
My 1978 280z will not start and I've narrowed it down to a fuel issue. I replaced the pump, cleaned the tank, and pretty much everything else. I have 36 psi of fuel pressure. So I'm pretty sure it's the injectos. Should i take them out and look at them? How do I know if there bad?
Id think the first one is easier. You can just pull each plug off of the injector and then crank the car to see if its getting a signal. Pulling the whole fuel rail would be like two large bolts plus all the bolts holding on the individual injectors. 2nd option could also result in you possibly finding broken pintle (I think thats what theyre called) caps or cracked injector spacer/isolators.
Edited by Challenger
