awoz87 Posted July 12, 2010 Share Posted July 12, 2010 ok so i picked up an l28 to drop into the 240z i bought and shortly after i got it running found out coolant in the oil. i figure its a headgasket and i had a new one laying around so i put it on. got it all back together, and running only to find more coolant in the oil. now when i had the head off i noticed two small cracks in the dome of the combustion chamber in cyl 4 and 5. they were similar cracks, coming from the valve area and going out the edge. now i know this should have been a huge sign right there but i was hoping it would not be an issue (stupid i know) what i want to find out though is this definitely the cause of coolant mixing with the oil? or should i be looking somewhere else for that? Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted July 12, 2010 Share Posted July 12, 2010 I'm pretty sure you need a new head regardless.... small cracks like hairline? or big enough to fit a fingernail in? Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted July 13, 2010 Administrators Share Posted July 13, 2010 Those cracks sound like the tell tale over heated cracks that go through to the water passage. Most guys just scrap the head and find another. It is possible to save the head, if you want to invest the time and money into having it welded and machined, though that can get costly. Also, please make an effort to capitalize when you post, (it's one of the forum rules). Hope that helps. Quote Link to comment Share on other sites More sharing options...
awoz87 Posted July 13, 2010 Author Share Posted July 13, 2010 Sorry. Yes, hairline cracks. Already searching for a new head, may end up just swapping in a KA. Thanks for the help though guys. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted July 13, 2010 Administrators Share Posted July 13, 2010 KA swap would be cool. Quote Link to comment Share on other sites More sharing options...
