pcakes55 Posted August 4, 2010 Share Posted August 4, 2010 I'm in the process of cutting/welding an oil return line from my turbo oil pan to my N/A oil pan in order to work with my N/A oil pickup tube. Anyways, I noticed on the TURBO pan that there was a bung (in the sump) for what must be an oil temp sensor, but I'm confused because the hole does not go all the way through; thus, the oil does not actually make contact with the sensor. So...is this for a temp sensor? And if so, is it stock? or did the person before me weld it in. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted August 4, 2010 Share Posted August 4, 2010 It is an oil temp sensor. On my pan (turbo), the sensor is exposed to the oil. Quote Link to comment Share on other sites More sharing options...
z-ya Posted August 9, 2010 Share Posted August 9, 2010 It is an oil temp sensor. On my pan (turbo), the sensor is exposed to the oil. Mine too. I drilled out the stock temp sensor and tapped it with an NTP thread so I could use an Autometer sensor. Quote Link to comment Share on other sites More sharing options...
