Challenger Posted August 30, 2010 Share Posted August 30, 2010 (edited) Picked up a Hx35w for free from member "mastermechanic", thanks again Josh! Anyways, Ive been reading on how to use it on my car and had a few questions. Regarding the split housing, is it basically only beneficial with the use of a proper manifold? Is using the stock manifold just not utilizing its full potential or will there be adverse effects? The housing hits the manifold so ill just need to use a spacer correct? It appears that the top two holes on the exhaust turbo housing bolts are threaded while the bottom two are not. I drilled them out and it slides on now (without intake housing). As for the spacer will just any T3 to T3 flange work? Ill be switching over the wastegate from my stock turbo to the HX35w so I can keep the boost down where I want it. Thanks! Edited August 30, 2010 by Challenger Quote Link to comment Share on other sites More sharing options...
bobbyc Posted August 30, 2010 Share Posted August 30, 2010 i have the hx53 on my z...i few others are running them...i had to create a spacer to get it to fit...the cold side is too big so it would hit the exhaust manifold and i couldn't just bolt it up. Quote Link to comment Share on other sites More sharing options...
Noddle Posted August 30, 2010 Share Posted August 30, 2010 You want something like this, the only problem I found, is I'm running two gaskets, and the inside one leaked on me, so I'm going to weld it to the manifold Nigel Quote Link to comment Share on other sites More sharing options...
Challenger Posted August 30, 2010 Author Share Posted August 30, 2010 Cool. Thanks for the picture. Doesnt look like it needs much... when I mocked it up I thought it would take more than a half an inch but it looks like yours is just half an inch. Im going to see if I can get a t3 spacer cut out at school on the plasma cutter as well as check on longer studs and an adaptor fitting for the oil feed line. Also, I noticed the original oil drain line fits on the holset. Looks like Ill need to just cut it down and run a longer tube. That is after I rotate the housing 90 degrees. Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted August 31, 2010 Share Posted August 31, 2010 Try and port/enlarge your oil return, Most stock returns are to small for what the holset require Anyone here running a hx40 yet ? I have one mounted to my l28, Which isnt running yet, would love to see some numbers Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 1, 2010 Author Share Posted September 1, 2010 The return is actually really close to the size of the holsets. Also how thick a spacer are you guys using? Im going to measure it when get home. Im getting a t3 flange spacer cut in town for like 20-30 bucks so I need to decide what size tonight. Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 2, 2010 Author Share Posted September 2, 2010 Stopped by a diesel shop in town, they had turbos sitting all over the place.. including an hy35. Anyways they were able to get me a 12mmx1.5 banjo fitting to fit the hx35w. The stock banjo fitting is 12x1.25 so this will work perfect with the stock oil lines. Also talked to him about feeding the turbo as well as the drain. He said it was important to have no places where it turns more than 45 degrees. It should be a strait shot, or very close to strait right into the oil pan so it doesnt back up and go through the seals into your intake and exhaust housings = lots of smoke. He had a funny story about that. haha Ill be cutting my stock return line down or checking to see what a used one originally for the holset costs so I can run a new hose to the oil pan. Quote Link to comment Share on other sites More sharing options...
Noddle Posted September 2, 2010 Share Posted September 2, 2010 The return is actually really close to the size of the holsets. Also how thick a spacer are you guys using? Im going to measure it when get home. Im getting a t3 flange spacer cut in town for like 20-30 bucks so I need to decide what size tonight. I had this laser cut for me this week for $10 Aus dollars, about $8 US. I made this so it fits better on the manifold where I needs to weld it ( it only fits one way ) Rename "Weld Flange.dwg.zip" to "Weld Flange.dwg" , it wouldn't allow me to upload with a .dwg file name for some reason. It's 12mm thick. Nigel Weld Flange.dwg.zip Quote Link to comment Share on other sites More sharing options...
jacob80 Posted September 2, 2010 Share Posted September 2, 2010 I have an HY35 sitting on the shelf for my next motor. I would assume the banjo bolt for this unit will also be 12x1.5, correct? This will be a good source of information. I've talked with a member on here and he put down 415hp on a customer car with a custom cam and an HY35. Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 2, 2010 Author Share Posted September 2, 2010 If you have the original ZX turbo banjo bolt try to thread it in. If it goes in a little and stops the hy is most likely a 12x1.5. Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 3, 2010 Author Share Posted September 3, 2010 But note that the hy from what Ive read doesnt need a spacer, its more bolt on and go. Although youll most likely need to clock the housing for the oil lines to line up correctly. Quote Link to comment Share on other sites More sharing options...
voong413 Posted September 18, 2010 Share Posted September 18, 2010 (edited) just got myself an hx35 too!! and how did you end up running the oil lines?can you guys post pic?! Edited September 18, 2010 by voong413 Quote Link to comment Share on other sites More sharing options...
