dsommer Posted September 13, 2010 Share Posted September 13, 2010 TOOL DEFINITIONS: DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted part which you had carefully set in the corner where nothing could get to it. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, ''What the...?’’ ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age. SKILL SAW: A portable cutting tool used to make studs too short. PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of. TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper. EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle. E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use. BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge. TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect. CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle. AVIATION METAL SNIPS: See hacksaw. PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. HOSE CUTTER: A tool used to make hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. MECHANIC''S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while wearing them. DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling ''DAMMIT'' at the top of your lungs. It is also, most often, the next tool that you will need Quote Link to comment Share on other sites More sharing options...
z2go Posted September 13, 2010 Share Posted September 13, 2010 Amazing! At least I'm using all of the tools in my garage properly. Hahaha! Quote Link to comment Share on other sites More sharing options...
Namor Posted September 13, 2010 Share Posted September 13, 2010 I've used probably 80% of the tools in the manner in which they were defined...working on the other 20% Quote Link to comment Share on other sites More sharing options...
johnc Posted September 13, 2010 Share Posted September 13, 2010 MIG WELDER - A powerful electric tool used to burn holes in sheet metal and create metal sculptures that resemble porcupines. Also good at using up vast amounts of expensive metal wire and inert gasses. TIG WELDER - A mystical, magical tool used to make very beautiful and expensive metal objects that have no practical use. Turns people who use this tool into Prima Donnas who heap scorn on those who us other forms of welding. PLASMA CUTTER - A tool that uses the 4th form of matter to burn large holes in everything exactly where you don't want them. It also magically stops working at random times. A more effective fire started then a OxyAcetyline torch because it can ignite certain metals that cannot be extinguished. TUBE BENDER - Powerful and effective tool for bending pipe and tubing into shapes that almost but not quite fit the original template or plan. Very ineffective at making a second try at a bend after just missing the correct angle. Does not work as an un-bender. Quote Link to comment Share on other sites More sharing options...
heavyweight280 Posted November 18, 2010 Share Posted November 18, 2010 This almost brought tears to my eyes. So true Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted November 18, 2010 Share Posted November 18, 2010 Copy paste. Seen it before at 240z8.com Quote Link to comment Share on other sites More sharing options...
mxgsfmdpx Posted November 18, 2010 Share Posted November 18, 2010 Hahaha. Perfect. Quote Link to comment Share on other sites More sharing options...
