automatic transmission cooler question
I have done a few searches but failed to find an answer to how you guys on here addresses the issue of a ATC in your Ls1Z rides.. According to the JTR website they no longer provide this option in there radiators.. Did you guys just find and mod a stock F body radiator and fit it into the Z????
Thank you
Simon
The cooler is off of a Volvo XC90. I just grabbed it from my work from the warrantee room. The brackets that are connected to it are factory, I just bent them up a little bit to make 'em work with where I mounted it. I also welded on -6 male bungs to the end of it to run the Stainless line. I am not running a fan on mine at all. I also run this same cooler on my 1971 Chevy C20 truck.
