jturbo06 Posted September 19, 2010 Share Posted September 19, 2010 new to forum i just bought my first 280zx for 400 its a 81 turbo auto, 2 things the car doesnt start theres no spark at the coil but theres voltage, the bracket thingy with the wires i cant remember what its called is new, good grounds i added 2 new ones 1 to the block and one to the body, coils new and ecu is good injectors fire and green led on ecu os wtf? anyho i also have 3 connectors under the steering wheel loose heres some pics someone please help my fiance wont stop complaining at me for buying another car that doesnt run!!! Quote Link to comment Share on other sites More sharing options...
hughdogz Posted September 19, 2010 Share Posted September 19, 2010 That thingy you're talking about is the igniter that is part of the coil bracket mount? I' not as familiar with the '81 ZXT's. I don't think those loose wires under the steering column are the cause of no spark. It's possible that the igniter isn't hooked up to the coil correctly. If the ECU is firing the injectors it's likely that something weird is going on with the igniter. I believe you can check if spark is possible by disconnecting the ground on the negative side of the coil while it's powered up with key ON, but I'm not 100% sure on that. Good luck! Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted September 19, 2010 Share Posted September 19, 2010 how did you determine you have no spark? do you have fuel pressure? you need to describe what you have diagnosed in order to get a reasonable answer otherwise all you get is flamed. pictures of wires are really of little value. download the fsm from xenon. look at the schematic and find the wires by color you have questions on and you too will know the answer. Quote Link to comment Share on other sites More sharing options...
jturbo06 Posted September 19, 2010 Author Share Posted September 19, 2010 well i grounded the coil wire that goes the the dizzy to check for spark and there isnt anything Quote Link to comment Share on other sites More sharing options...
hoov100 Posted September 19, 2010 Share Posted September 19, 2010 When you have everything hooked up do you get spark when you ground out the coil wire while cranking the car over? If spark is your only issue I would suggest checking over the wiring diagram and tracing wires and checking components. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted September 19, 2010 Share Posted September 19, 2010 (edited) NVM. Edited September 19, 2010 by hoov100 Quote Link to comment Share on other sites More sharing options...
jturbo06 Posted September 20, 2010 Author Share Posted September 20, 2010 ive been going over the diagrams and im still confused, anyone got a pic of the wires or somethingk that can help me out? Quote Link to comment Share on other sites More sharing options...
