mistah mofro Posted October 11, 2010 Share Posted October 11, 2010 (edited) First thing that happened Was after a small mountain run, there was a slight grinding sound. You can hear it right in front of the of the bellhousing, so next day I dropped the tranny retightened the pressure plate and made sure nothing was wrong but everything seemed fine, but theres two stripped bolts on the pressure plate. Second thing that happen made about another "Run" after that there was a very loud whine in 2nd and 3rd, then the next day I couldnt shift into gear like as if the Clutch went. Characteristcs like cant put into gear in while moving or sitting still with the clutch pedal all the way down, so i grab all the essentials clutch/pressure plate/release bearing/pilot. Now the problem is when I went to go move it for street cleaning it shifting fine, but there was some added vibration at random RPMS. Its a 73 240z with a 280zx tranny also it would throw 5th out of gear, i mean like it would never hold 5th gear this was happening before I had the car though. So now Im baffled, any ideas anyone? Edited October 11, 2010 by mistah mofro Quote Link to comment Share on other sites More sharing options...
mistah mofro Posted October 11, 2010 Author Share Posted October 11, 2010 bump Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted October 11, 2010 Share Posted October 11, 2010 It would seem that you need to O-haul the trany. Mongo Quote Link to comment Share on other sites More sharing options...
