ams7 Posted October 18, 2010 Share Posted October 18, 2010 My mechanic says that the clunking noise in the rear of the car is coming from the rear u joints on the axels. Told me to buy new stub axles with u-joints complete. Is he just being lazy (does not want to replace a cheap u-joint ) or is better and easier to get the whole axels? Also where do I get them for a good price, can I buy used or is this a new only part? Thanks for any advice. Jerry Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 18, 2010 Share Posted October 18, 2010 My mechanic says that the clunking noise in the rear of the car is coming from the rear u joints on the axels. Told me to buy new stub axles with u-joints complete. Is he just being lazy (does not want to replace a cheap u-joint ) or is better and easier to get the whole axels? Also where do I get them for a good price, can I buy used or is this a new only part? Thanks for any advice. Jerry He might confusing the drive shaft u-joins which are not replaceable (without some custom work being done) with the half-shaft u-joints which are. Or he might not know that the retaining clip is on the inside of the yoke, not the outside like most domestic cars. Check out Post #3 and #6 here. Zs have Type 2 (Post #6) half-shaft u-joints. If you can get up to the Portland area, this guy has a used set of half-shafts that you could bolt right in - http://portland.craigslist.org/mlt/pts/2008316276.html Or you can get new u-joints at most auto parts stores and either do them yourself or have them installed. Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted October 18, 2010 Share Posted October 18, 2010 One of mine was actually making clunks because the U-joint was destroyed to little bits. I had a spare set to take to a truck/semi place that does U-joints/driveshafts, and they had it ready the same day. It was not expensive, compared to buying one new shaft. Installing the new ones in was not hard either. Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 19, 2010 Share Posted October 19, 2010 (edited) Hey, I just re-read your first post and realized that you said that your mechanic said "buy new stub axles with u-joints". Mentally, I replaced "stub axle" with "half-shaft." You either heard him wrong or he's not too familiar with the cars. You might have him look again or have someone else take a look. The half-shafts just unbolt, remove four nuts at each end, and can be removed complete for easy u-joint replacement. Edited October 19, 2010 by NewZed Quote Link to comment Share on other sites More sharing options...
