awoz87 Posted October 21, 2010 Share Posted October 21, 2010 I did a bit of searching but could not find a solid answer. I want to know if I can run an 8ga wire from the pos off my 280zx alt directly to the pos terminal off the starter with an 80amp maxi fuse in line. I don't see where it would cause any issues but I want to double check. The reason I want to do this is the wires running into the car to the ammeter are getting very hot. Quote Link to comment Share on other sites More sharing options...
awoz87 Posted October 22, 2010 Author Share Posted October 22, 2010 no one?? Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 22, 2010 Share Posted October 22, 2010 Your question is a little confusing... Your ZX should have a voltmeter, not an ammeter. And if you follow the main charging wire from your alternator you should find that it already goes to the battery positive terminal through a fusible link. At least according to the 1981 diagram. What year is your car and do you really have an ammeter? Quote Link to comment Share on other sites More sharing options...
awoz87 Posted October 24, 2010 Author Share Posted October 24, 2010 Its a 73, with the zx alt conversion. sorry for leaving that out. Quote Link to comment Share on other sites More sharing options...
