Miles Posted October 24, 2010 Share Posted October 24, 2010 Application: 240Z sbc Camaro T5 transmision The clutch set up (flywheel and clutch pack) I bought did not come with clutch pack dowel pins. Do I need to install the dowel pins in the flywheel for the clutch pack? Is there a problem if they are not installed? Quote Link to comment Share on other sites More sharing options...
revlis240 Posted December 7, 2010 Share Posted December 7, 2010 miles, im searching my memory from 10 years ago (last time i did a clutch) and i recall also not having the dowel pins on my flywheel. If i was to guess i think they AID in the lining up of the pressure plate but are not absolutely necessary. Just make sure you torque the PP to the correct specs and you should be fine. Line up the PP as if the dowel was there ofcourse. I may be totally wrong, but if it were me, thats what i would do! Quote Link to comment Share on other sites More sharing options...
Miles Posted December 7, 2010 Author Share Posted December 7, 2010 I used ARP bolts and torqued them to spec. Thanks Miles Quote Link to comment Share on other sites More sharing options...
