adivin Posted September 13, 2021 Share Posted September 13, 2021 1 hour ago, Mayolives said: I'm not sure what your question ("situation") is. I have used the POR 15 fuel tank cleaning system 2 times and it worked great. If you followed the instructions and made sure the pick up plumbing was free and open, all should be well. What exactly are you having a problem with? Well, the pick up plumbing is the problem. I suspect I have a partial blockage at the end of the pick up tube due to the sealer. I can still blow air through it, but I think it should flow a bit better. Of course there is no access to it. I was able to sneak a peak by snaking an inspection camera in there and I saw a glob of sealer on the end of the pick up tube. Essentially it's the same problem the original poster had. Perhaps all is well and I'm being paranoid. Quote Link to comment Share on other sites More sharing options...
