bodie Posted November 30, 2010 Share Posted November 30, 2010 So after a 6 month break finally get back to the car. Had installed it once using jtr mount and found it was too close to the passenger side strut tower with the headers. so as a tes fit i use 1.75 in spacers on each side and found it to be ideal. now i intend to get another driver jtr spacer and have both milled down to the 1.75. also i have an old azc front lower control arms that i intend to use but am missing the heim end spacers. Does any one know the exact size or where i can order a set? i believe it to be 1" spacer on each side but not sure at the moment. Quote Link to comment Share on other sites More sharing options...
z2go Posted November 30, 2010 Share Posted November 30, 2010 So I'm guessing you are planning a turbo setup? If not, your headers are on upside down Have you worked out transmission/driveline fit yet? The JTR kit is supposed to place the transmission in a near-stock position, you might be having to cut a hole in the side of your center console to get the shifter through. Sorry, I don't have an answer to your question, though. Quote Link to comment Share on other sites More sharing options...
bodie Posted December 1, 2010 Author Share Posted December 1, 2010 yea twin turbo,with a t56, and according to my measurements the shifter should come up in the middle of the hole. ill find out later this week when i test fit the transmission. and also as soon as i find my battery charger ill post better pics. Quote Link to comment Share on other sites More sharing options...
jhm Posted December 3, 2010 Share Posted December 3, 2010 Should be a mean set-up! Keep those updates coming, and good luck with the build! r/John Quote Link to comment Share on other sites More sharing options...
bodie Posted December 6, 2010 Author Share Posted December 6, 2010 some better pics with the transmission in place while i make a mount. Quote Link to comment Share on other sites More sharing options...
v8dats Posted February 22, 2012 Share Posted February 22, 2012 any updates on this? like the turbo headers. Quote Link to comment Share on other sites More sharing options...
