240z rear disc confusion
I am working on a rear disc brake conversion. I have the maxima brackets,but I want to use the vented 300zx rotors. I would also like to have a 2 piston rear caliper. I have been reading all the articles,i am a bit confused,any suggestions?
The only 300ZXs that had vented rear disc were 5 lug, which makes it that much more difficult. You may be able to have the rotors re-drilled, but I don't see it being worth it. Plus, single piston should be plenty adequate for the rear of a S30, but if you want it you'll probably have to figure it out on your own. Look into getting custom brackets made?
I don't think this is the right section for your question...
