RebekahsZ Posted December 13, 2010 Share Posted December 13, 2010 I need a recommendation for a new serpentine belt for an LS2 motor with A/C delete and power steering delete. I will use stock alternator as the only accessory and plan to use stock pulleys and idlers. I have Autozone, O'Reilly's and Advance Auto in my area. No NAPA or Crow Burlingam in my town. I've spent several blocks of time searching the topic and have come up dry, so I hope I am not asking a redundant question. Quote Link to comment Share on other sites More sharing options...
Zzeal Posted December 13, 2010 Share Posted December 13, 2010 Just use string to determine the length you need. Don't forget to position the tensioner to it's working position when measuring. Your local store (should) know the lengths of their serpentine belts. It worked for me, first try, with NAPA. Steve Quote Link to comment Share on other sites More sharing options...
kj280z Posted December 13, 2010 Share Posted December 13, 2010 Look here - post number 22 http://forums.hybridz.org/index.php/topic/82026-jci-ac-mount-alignment-issues/ Quote Link to comment Share on other sites More sharing options...
smoorenc Posted December 16, 2010 Share Posted December 16, 2010 Here is mine with #. Quote Link to comment Share on other sites More sharing options...
pokypine Posted April 19, 2011 Share Posted April 19, 2011 smoorenc, Do you have a pic of you complete belt routing? BTW, your build website is an amazing source of info on this project. Looks like you're getting real close. Thanks so much Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted April 20, 2011 Share Posted April 20, 2011 its just a 55.5" 6 rib belt. any parts guy with a brain should be able to either cross a napa number over, or find you one in house. Quote Link to comment Share on other sites More sharing options...
pokypine Posted April 20, 2011 Share Posted April 20, 2011 Thanks for the length Sunny Z. I'd still like to see the completed belt routing. The link to the thread above includes AC or some other accessory, and moore's pic only shows the single pulley. Quote Link to comment Share on other sites More sharing options...
mistafosta Posted April 21, 2011 Share Posted April 21, 2011 Thanks for the length Sunny Z. I'd still like to see the completed belt routing. The link to the thread above includes AC or some other accessory, and moore's pic only shows the single pulley. Do yourself a favor and either use a string or an old belt to measure the belt length and goto the store with that info. Any store can get you a belt that will work. Guessing off someone elses picture is really a bad way to go about getting the correct belt. Its 15 minutes of work that will make life a whole lot easier. Quote Link to comment Share on other sites More sharing options...
pokypine Posted April 22, 2011 Share Posted April 22, 2011 I understand how to find the length. I just want to see how people are routing it. When you do both PS and AC delete you're left with a combination of pulleys that doesn't work. I've seen that you need to add a ribbed pulley but I was just hoping to see exactly where it goes... Quote Link to comment Share on other sites More sharing options...
mistafosta Posted April 22, 2011 Share Posted April 22, 2011 I understand how to find the length. I just want to see how people are routing it. When you do both PS and AC delete you're left with a combination of pulleys that doesn't work. I've seen that you need to add a ribbed pulley but I was just hoping to see exactly where it goes... Ah, ok. I deleted everything on my car, but I run corvette accessories and a blower so it wouldn't be any help really. You should have the alt, wp, crank and a idler that is up top on the passenger side of the water pump. That doesn't work? Quote Link to comment Share on other sites More sharing options...
