Bennymac Posted December 22, 2010 Share Posted December 22, 2010 Anybody have any advice on what i need to do to prepare the engine bay of my 87 300zx to drop this RB25 into it? i feel a little stuck right now and any help would be awesome!! thanks, Ben Quote Link to comment Share on other sites More sharing options...
Calico Posted December 22, 2010 Share Posted December 22, 2010 I believe McKinny motor sports makes a kit. I know alot of ppl talk about the now obsolete 200ZR mounts, pan and cross member (JDM) Quote Link to comment Share on other sites More sharing options...
Bennymac Posted December 24, 2010 Author Share Posted December 24, 2010 sickkkk thanks a bunch!! McKinny is pretty legit, im definitely gonna look into them more... have you, or do you kno anyone who has done an engine swap on a 300 before? Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted December 24, 2010 Share Posted December 24, 2010 have you, or do you kno anyone who has done an engine swap on a 300 before? Yup, there's a guy in Aussie who has dropped a Leyland P76 donk in a Z31. I advise you read the stickies in the RB forum and Z31 forum, there's a reason they are stickied. Quote Link to comment Share on other sites More sharing options...
lookingoodzxt Posted January 7, 2011 Share Posted January 7, 2011 I`m doing the swap in my Z31, take a look at my post on z31performance.com http://www.z31performance.com/forum/viewtopic.php?f=13&t=16640 Quote Link to comment Share on other sites More sharing options...
Dramier Posted March 23, 2013 Share Posted March 23, 2013 You'll need engine mounts, crossmember and driveshaft modified or made. Some advice.. unless you have a decent budget to throw at it, don't bother. You'll need the cash for when stuff starts breaking. In particular the coils are expensive and hard to get. In the end, by the time you have an RB swapped in, the money you spent on that motor, that work, all the fabrication and crap, you could have a VG30 making twice as much power, twice as reliable and probably even a second block sitting around just in case. The RB swap in the Z31 in the United States is cool for sure, but just not really practical for a daily driver. If you're wondering how I know, I've had both an RB20 and an RB25 in my old Z31. As far as I've ever seen, I was the first to ever have an RB25DET running Z31. In hindsight, completely not worth the trouble. That's why I'm building a VG30 in my next Z. Stick with the old maxims... "If it ain't broke, don't fix it." and especially: "Keep it Simple Stupid." Best of luck if you do try and swap. Quote Link to comment Share on other sites More sharing options...
GodspeedZ Posted September 15, 2014 Share Posted September 15, 2014 (edited) I have a 87 z and I'm swapping engines to a rb25det, I have engine tranny (automatic transmission) ecu,harness,etc but I have to get the mounts cross member and modify driveshaft. I need to know were I can get the harness adapters or any other things I need to complete it. thanks in advance Edited September 15, 2014 by GodspeedZ Quote Link to comment Share on other sites More sharing options...
G-E Posted September 16, 2014 Share Posted September 16, 2014 You need a rear sump oil pan, enjuku has options specifically for the Z31, mckinney makes a rear sump for the S30 which may or may not work properly... The motor mounts are better off made locally, it's easy to do, and you should be able to modify the Z31 trans mount to work... Quote Link to comment Share on other sites More sharing options...
GodspeedZ Posted October 2, 2014 Share Posted October 2, 2014 need a little help on the wiring for engine swap. rb 25det into my z31. thanks in advance Quote Link to comment Share on other sites More sharing options...
