holset outlet ridge?
Z31TURBODRAY
A local exhaust shop should be able to do that for me right? while im there I can get the internal wastegate welded shut to right? Do the holset turbos have that type of internal wastegate setup?cuz im gonna be running an external wastegate, im not to familiar with Holset turbos.
it depends on the shop some exhaust shops can't weld aluminum. You need to weld the wastegate up also.
if you ship it to me I can weld up the wastegate and weld a 90 degree elbow on it
