PR280z Posted January 16, 2011 Share Posted January 16, 2011 I`ve decided to give the Z a RUSTOLEUM paint job.This is the first coat, next will be the sanding and then another coat.It will get a coat or two of clear for a nice shine.Here are some pics of my 1st rustoleum paint job. Will post pics of the outcome when done. KEEPING THE Z ALIVE! Quote Link to comment Share on other sites More sharing options...
Empire Posted January 16, 2011 Share Posted January 16, 2011 Is that the "aluminium colour"? I find with parts i sprayed in that colour that the metallic rubs off. So you just rolled this stuff on? Looks good. Quote Link to comment Share on other sites More sharing options...
PR280z Posted January 16, 2011 Author Share Posted January 16, 2011 Yes,that`s the color. I`ll be adding a touch of fine glitter /flakes to the clear coat for that sparkle. I hope it turns out well? If not i`ll redo it in another color. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted January 18, 2011 Share Posted January 18, 2011 Did you spray or roll on? How's the orange peal? What ratios did you use? Quote Link to comment Share on other sites More sharing options...
PR280z Posted January 18, 2011 Author Share Posted January 18, 2011 It`s the 1st coat using the roll-on method. I did`nt mix it because it was very thin from the beginning,just a good stir and apply. It did take much longer to dry,i guess that`s what the thinner(spirits)is for. I also did the insides of the fender and will be applying rubber undercoat. I will be hitting it with 600g after the 2nd coat. I`ve seen some good results with this method so i`m giving it a try. Quote Link to comment Share on other sites More sharing options...
Empire Posted January 18, 2011 Share Posted January 18, 2011 even the engine bay and headlight scoops were done with a roller? I've never seen it lay out that smooth before. Looks great. what are you using for clear? what method to apply? Quote Link to comment Share on other sites More sharing options...
PR280z Posted January 18, 2011 Author Share Posted January 18, 2011 I actually was surprise also on how it lay out smoothly. I do`nt know how thick other rustoleum paints are,but this color sure was very thin, like water.What you see was all done with the roller method.Yes, even the engine bay.I`ll be spraying a lacquer base clear coat.So far i like the results. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted January 23, 2011 Share Posted January 23, 2011 I'm doing this exact same thing right now. I'm spraying mine on with a cheap Harbor Freight gun though. Quote Link to comment Share on other sites More sharing options...
PR280z Posted January 24, 2011 Author Share Posted January 24, 2011 I'm doing this exact same thing right now. I'm spraying mine on with a cheap Harbor Freight gun though. What color is that? Hope it turns out good for you. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted January 24, 2011 Share Posted January 24, 2011 I just got a pint of semi-gloss white and had them tint it with a green that I liked. The original green was much darker but of course it was not made to be added to rustoleum. I actually really like the way it came out. Quote Link to comment Share on other sites More sharing options...
PR280z Posted January 24, 2011 Author Share Posted January 24, 2011 The color sure is different, similar to the the mustang/drift car.The color stands out to much for my taste. GLW the project. Quote Link to comment Share on other sites More sharing options...
75zcar Posted January 25, 2011 Share Posted January 25, 2011 The color sure is different, similar to the the F&F eclipse. The color stands out to much for my taste. GLW the project. Fixed Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted January 25, 2011 Share Posted January 25, 2011 (edited) Fixed I believe the reason he is painting it that shade of green is because he had a 280zx that was a rare stock green, and obviously liked the color. Edited January 25, 2011 by 19762802+2 Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted January 25, 2011 Share Posted January 25, 2011 ^^^ yup,(1979 citrus green) this is not the end result color. Sorry for the thread jack. Love the way yours is coming out. I am using a 1:1 ratio of paint and thinner. So far it seems to be drying with in 7-8 hours. Keep us updated on how yours is coming! Quote Link to comment Share on other sites More sharing options...
PR280z Posted February 4, 2011 Author Share Posted February 4, 2011 (edited) Just testing the clearcoat on the booster lid. Still needs the 2000g wet sand and wax for a deep shine. Edited February 4, 2011 by PR280z Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted February 4, 2011 Share Posted February 4, 2011 What clear coat did you use? Quote Link to comment Share on other sites More sharing options...
PR280z Posted February 5, 2011 Author Share Posted February 5, 2011 What clear coat did you use? I used the rustoleum gloss on the booster lid. I`ll be testing a lacquer clearcoat on the other lid and compare the results. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted February 8, 2011 Share Posted February 8, 2011 Awesome please pm me or just post it so I will know what works best. Thanks! Quote Link to comment Share on other sites More sharing options...
