Gollum Posted January 22, 2011 Share Posted January 22, 2011 Ok, someone with a running L28ET please help me. Run out to your car and tell me the wiring of the TPS. My motor's TPS wiring was a joke so I got a TPS connector at a junkyard from a NA, which has different colored wiring. So if someone can tell me which color wires go to which positions that'd be wonderful. Only two dang wires and I'm not sure I've got them connected right. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted January 23, 2011 Share Posted January 23, 2011 l28et only uses two wires for the closed throttle switch. One is the center pin and the other can be figured out by checking which pin has continuity with the center pin when the throttle is fully closed. If none do, then tps needs adjustment or is bad. Quote Link to comment Share on other sites More sharing options...
stravi757 Posted January 23, 2011 Share Posted January 23, 2011 Ok, someone with a running L28ET please help me. Run out to your car and tell me the wiring of the TPS. My motor's TPS wiring was a joke so I got a TPS connector at a junkyard from a NA, which has different colored wiring. So if someone can tell me which color wires go to which positions that'd be wonderful. Only two dang wires and I'm not sure I've got them connected right. (Standing next to your driver side fender) The right wire is blue with black stripe, and the middle wire is solid blue. Quote Link to comment Share on other sites More sharing options...
Gollum Posted January 23, 2011 Author Share Posted January 23, 2011 (Standing next to your driver side fender) The right wire is blue with black stripe, and the middle wire is solid blue. Sweet! That's what I was looking for. Thanks a million. Quote Link to comment Share on other sites More sharing options...
