Installed Stereo now no guages or turn signals
gjc5500
Just like the title says, i installed a stereo in my 73 240 and now there are no turn signals or gauges working. I had a stereo in the car before and just used the existing wiring. any advice would be appreciated, thank you.
I'm just going out on a limb here, but have you checked your fuses? :)
There is a connector underneath the steering column cover that can come loose and cut power to your gauges. This happened to me and I don't recall the wire color but it is a single bullet connector. When I took the cover off and re-seated the connector my gauges started working again.
so i found the problem, sorta. if i pick up the fuse block and turn it, i hear a click, and nothing works. after doing this a few times and setting it back where it belongs, everything started working again. I think its probably time for a painless kit.
