Piston Search
Ok here is my issue...
I bought a short block N42 built by Marc Sayer, performance engineering in 1999 that was wrapped and stored.
He put dished pistons in it, but I want to go with flat tops and bump up the compression.
To the point…
I am having a hard time finding flattops pistons 040 over.
Not looking for forged, It should be under 180 hp so cast is fine.
Does anyone know who sells them or could you please point me in the right direction?
This is my base specs "for now"……(going in a 70/240z)
• l2.8 N42 Block flat top pistons punch 1mm over
• E88 head w/ mild porting
• 1mm head gasket
• 270-80F cam grind III
• New timing set
• N36 intakes ported w/ early z balance tube
• 4 screw SU Therapy w/roller bearings, modified jetting, nozzles
• 3/2/1- 2.5†Header jet coated w/ new twin tip exhaust
• Lighten fly wheel
• new clutch, pp and t/o bearing
• HEI Points less distributor
• Turbo oil pump
Thanks for the help, I will take all I can get. Capt Mark
ps... I searched pretty hard all day
Are you sure you want to bump the compression up that high? From my understanding (unless you're running very high octane race gas), using flat tops in addition to a 1mm head gasket and E88 head is going to result in an extremely high and likely unmanageable ratio. What's your current measured CR with the dished pistons?
We get 91-93 octane here in Florida and this is a weekend car so gas is not an issue.
Attached is the difference with the online calculator.
It is just a base starting point, with a 1.27mm gasket drops to 9.88CR.
I have friend that did this build w/ stand pistons and it is very strong.
