MS 1 v2.2 ignition wiring confusion
98cobra+75280z
I am in the middle of wiring my 75 z and I am running into a snag with the igniton wiring. I have a MS 1 v2.2 board with a relay board. I have all of it wired up but I am unclear on how to wire the ignition switch. I am also confused on where to install the jumper into the relay board so I can use the fidle relay to power my ignition signal. All the posts I have read are very vague by only saying to install a jumper. Is there any way someone may be able to post a picture of how they wired the ignition switch and possibly the relay board if anyone is using the v2.2 board. Thanks you guys for any help
kevin
I don't have Megasquirt but I've been reading up on it. You said that you've been reading posts but have you been reading the installation manuals? Granted, there's a ton of info out there that's difficult to wade through, here's some suggestions.
These might have what you need -
http://www.megamanual.com/v22manual/mwire.htm#safety
http://www.megamanual.com/v22manual/mwire.htm#idle
These might be helpful -
http://www.megamanual.com/mtabcon.htm#22
http://www.diyautotune.com/tech_articles/megasquirt_install_writeups.htm
http://www.diyautotune.com/tech_articles/tech_articles.htm
http://www.diyautotune.com/msmoreinfo.htm
