Building my 3.0 L soon - pics
inline6
I'm finally going to be building a full custom engine. I hope to have it built over the next couple of months. I worked all winter on the cylinder head... Porting, unshrouding valves, porting intake manifold, rebuilding Mikuni 44's, refacing intake manifold etc.
The crank is at the cam grinder. It is being offset ground for more stroke, lightened, balanced, and NPT plugs installed. It should be coming back across the country to my engine builder this week. I'll be certain to get some pics before it goes in the block. For now, here are some pics of the Mikuni setup and the cylinder head and cam. The cam is a Sunbelt grind.
post-4218-086323800 1301189438_thumb.jpgpost-4218-011831700 1301189461_thumb.jpgpost-4218-059116600 1301189480_thumb.jpgpost-4218-026892000 1301189502_thumb.jpgpost-4218-080892700 1301189529_thumb.jpgpost-4218-064443400 1301189558_thumb.jpgpost-4218-079867400 1301189654_thumb.jpgpost-4218-042673600 1301189724_thumb.jpgpost-4218-078484900 1301189902_thumb.jpgpost-4218-064767700 1301190117_thumb.jpgpost-4218-080225900 1301190156_thumb.jpgpost-4218-071539800 1301190215_thumb.jpgpost-4218-042824500 1301190247_thumb.jpgpost-4218-056100000 1301190274_thumb.jpgpost-4218-092358000 1301190301_thumb.jpgpost-4218-090471900 1301190329_thumb.jpgpost-4218-069632900 1301190359_thumb.jpgpost-4218-025349600 1301190418_thumb.jpgpost-4218-027057700 1301190457_thumb.jpg
Edited by inline6
  • Replies 109
  • Created
  • Last Reply
Top Posters In This Topic
The head is a late style E88. Here is what the combustion chamber looks like stock (taken from the pinned post in this forum which identifies the heads):
The combustion chamber on this head is certainly not the most ideal, but I'm hoping it won't hurt things much with my combination. The cc's are 45.6. Mine has been milled about .017" total. With flat topped (forged) pistons, the compression ratio is going to be about 10.7 to 1. If I put a dome on the pistons, I can get some quench back, yes?
After I have the motor together, this TWM 45 setup is going on to replace the Mikuni's. I plan to use the Electromotive FI for ignition with both setups... get the Mikuni combo dyno'd and then switch over to see how much more I get from the FI.
TWM 45 mm throttle body FI set up:
Electromotive tec FI/ignition:
Edited by inline6
No crankshaft yet... getting antsy. Anyway, here are a couple of pics of the in air box (from England) and filter arrangement. I had to cut a hole in the firewall for the 3" inlet. Not sure where I am going to put the air filter yet. Probably will cut the pipe a bit shorter and move the filter out of the air stream for the radiator. Radiator is a crossflow unit from Jags that Run.
post-4218-086461400 1301966604_thumb.jpgpost-4218-061688400 1301966613_thumb.jpgpost-4218-002391700 1301966624_thumb.jpg
Edited by inline6
I'll be watching your progress as it's similar to my project.
I'm going forged 89mm domed pistons with forged FJ20 rods using P90 head.
Using 44PHH Mikuni's with TWM manifold and cold air box.
Haven't done any block or crank work yet, just collecting for now.
So hence. The interest in your build
Interesting combo. How long are the FJ20 rods? I'll be using some Eagle aftermarket rods from a Toyota Celica. They are 5.428" long and weigh about 565 grams.
Here is a link to some of my engine build info. These numbers have changed just a touch, but I'll update the info at the link soon:
EngineBuild
The air box I have is a direct copy of the TWM box by the way. I confirmed that - contacted the guy that originally made them. Now they are sold by someone else. Don't know if you plan on using a TWM box with the TWM manifold... Anyway, this one is much better quality than the TWM box (I got one of those with the FI setup I bought on eBay). This one is made of fiberglass. The walls are a bit thicker also. I think it was around $250 with no customs or duties. Let me know if you would like the contact info.
Kameari parts arrived today from Japan. Only took 4 days for delivery! No customs or duties...
Is that a little radioactive glow coming from those parts :D
Seriously, nice build you got going.
Pete
Pm´d You about that air box details..
So the box is £160 plus shipping - which is currently $261US plus shipping. He sold me a cosmetic blem for a few dollars less... Here is the website:
http://www.mjpshop.co.uk/product_info.php?id=113&pid=437
I paid by PayPal. Here is the contact info:
Mike Feeney at MJP (Eastern Auto)
Brentwood, Essex
Here is a thread on zclub.net with lots of info about the box:
http://zclub.net/forum/240z-260z/16484-air-box-fitting-tips.html
  • 3 weeks later...
Crankshaft should be arriving any day now. Can't wait... In the mean time, I've learned from reading the forums that combustion chambers should be polished - not glass beaded! So, I did that.
You can see the undercut on the side of the chamber here. I was copying a 510 head I had done by Malvern racing long ago.
I also learned from the forums that the N42 block is the one to use for 89 mm bore. Wow. I was going to use my F54 block. Luckily, I still have my N42 block from an earlier motor. How about this casting flash???
I spend a couple of hours with an air powered hand held belt sander... belts are 3/8" wide by 13" long, one of my latest tool aquisitions. Going through belts rather faster than I had hoped. I am using Norton 60 grit. Looks like it is going to take about 5 to do most of the inside of the block.
Anyone have some left over Glyptal on the shelf? I don't think it takes a full quart to do one block, but that is the only quantity I can find for sale. :huh:
Edited by inline6
Try going at it with a carbide bit first, and then following up with the sander. I'd imagine that the casting flash would cut through those belts rather quickly!
Where are you getting your rods from?
I had come to the same conclusion when I was designing an over the top turbo build for a customer who wanted to "keep it all datsun" under the hood. :rolleyes:
