jdm vg30dett p/s pump alignment
tech1_22
hello all, i'm new to the board and would like to pose a question to everyone. is there a difference between the harmonic balancer and or p/s pump pulley on a jdm vg30dett and an n/a vg30? my shop has inherited a huge set of problems/finish work on a half finished '92 300zx jdm swap, wiring, pipe routing, exhaust etc. etc. we've gotten everything finished up and the car running and driving great except the p/s pump belt keeps wanting to run one rib off the p/s pump pulley. it seems that the p/s pump pulley and harmonic balancer are misaligned. any ideas?
  • 1 month later...
CHeck the PS pump mount, I bet it's not installed correctly. The PS pump has a bracket at the bottom and then a scissor tensioner ajusting bolt at the top. If that tensioner isn't put together properly it'll cause things to be out of alignment. Search on here for the FSM, and I'm sure you'll see what I'm talking about.
  • 9 months later...
