Speedhut speedometer gauge faces question
logan1
Ok so i got a set of Speedhut gauge faces to install onto my stock gauges. The question is about the Speedhut speedometer gauge face.
The stock metal gauge face has a very thin pin at the start that prevents the needle from going anti-clockwise past 20mph. The Speedhut speedometer gauge face does not have a hole for this needle. Do i simply break the needle off and install the Speedhut gauge face over the stock one or do i have to make a hole in the speedhug gauge face for the stopper pin to come through the speedhut gauge face
thanx for the help
John
thanx for the help
John
Here's a picture of the speedhut gauge face installed on my speedo - I did not experience what you're talking about so pics would help
I subsequently changed to their tach and GPS speedometer so I have this stock tach and stock speedo already converted and ready for someone if they want them
Are you doing this just to get white faces or to get the SpeedHut gauge face? Anyways I would personally drill a hole/stopper.
I want the speedhut gauge face with the reverse glow working.
Well my car is a 1970 series 1 240z and it seems to have a bunch of 1 off parts that are alway a PITA for modification.
Below are pictures of my speedo; its hard to see the stop pin in the middle of the 20mph callout.
I think your best bet would be to call Wade at Speed hut and ask if it's ok to drill a hole in the gauge face - it may effect the indiglo operation
Also, I'm not sure if the gauge will work correctly with the stop removed - mine are the 280z style -
  • 4 weeks later...
I installed a set of reverse EL glow on my '76. I had them make a custom hole for the charge light on the voltmeter. When I called and talked to tech support about the hole, they (not sure who it was, its been a few years now) said I could make the hole myself if was comfortable doing it. But I opted to let them do it. While installing I also had to trim the clock face to fit, and the face seemed to delaminate on the trimmed edges. So now I would be very uncomfortable trying to make a hole in them.
I removed the charge light from the gauge - it's not needed - haven't finished the wiring on it yet though...
If it reads more than 12 volts it's charging!
