L28et CAS
ComicArtist
Swapping an '81 L28ET into my '78. I have all the parts that came with the motor, including harness, all the sensors, vacuum stuff, ect. However, the CAS bracket was disconnected from the block where it bolts up. Just wondering if I can bolt it back onto there or if I need to turn the crank to TDC or anything before I put it back on. Does it require any timing at all? Thank you!
Also, the spark plug wires are all disconnected. If anyone has a diagram or picture of which wires go to which plug from the distributor, I'd appreciate it greatly.
Thanks!
Ben
Highly recommend not messing with the stock 81 CAS.
The 82 and 83 CAS can easily be supplemented in its place.
To answer your question though you can simply bolt the bracket and CAS back in place. Leave the lock nut loose, attach your timing device, and adjust the adjuster nut until you get the desired timing. You do not have to rotate the engine to TDC for this install.
