Sugee_S30_Z Posted May 9, 2011 Share Posted May 9, 2011 (edited) I'm a new z owner sorry.. Can someone tell me where it is? A picture of the location would help thanks Edited May 10, 2011 by Sugee_S30_Z Quote Link to comment Share on other sites More sharing options...
Sugee_S30_Z Posted May 10, 2011 Author Share Posted May 10, 2011 On 5/9/2011 at 3:42 PM, Sugee_S30_Z said: I'm a new z owner sorry.. Can someone tell me where it is? A picture of the location would help thanks bumb up still need help!!! Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 10, 2011 Share Posted May 10, 2011 The 1972 FSM will probably get you close - http://www.xenons30.com/reference.html I believe that there is no relay, headlight power runs through the combination switch and the dimmer switch which is part of the turn signal stalk. Most headlight problems are from dirty contacts in the dimmer switch. Quote Link to comment Share on other sites More sharing options...
rejracer Posted May 11, 2011 Share Posted May 11, 2011 Power runs from fusible link on starter to headlight switch to fuse block to Common terminal on headlights back to dimmer switch then to ground. Yes, 4 passes through the firewall! Quote Link to comment Share on other sites More sharing options...
